Salut!
je ne retrouve plus le post de
kallem qui annonçait la sortie en 2008 d'une nouvelle version de la Microjet de Multiplex (plus rapide!!! ;) )
Est-ce que c'est cette référence : #214202 ???
car pour moi c'est juste qu'elle est blanche et vendue en sachet plastique???
Merci et A+
Teilesatz microJET weiss, im Kunststoffbeutel #214202
ELAPOR foamparts set complete
This is the hot jet for the advanced model pilot. Due to the model’s
size, its roll rate and general agility are extreme, setting new standards
in terms of fun per pound. Nevertheless, the aeroplane’s
flying characteristics are nicely balanced and the handling excellent.
The micro-JET is supplied virtually as a one-piece model;
only the fi ns and cabin are supplied separately, together with the
landing guard and motor cover. The two Nano-S servos are simply
inserted into the servo wells and secured with a drop of glue, while
the control surfaces feature integral moulded hinges.
• Supplied with white moulded parts
• No painting required
• Tough ELAPOR® moulded foam components
• Vacuum-moulded parts to protect fuselage bottom and servos
• Canopy-Lock canopy latch
• Multi-colour decal sheet
• All small parts required
• Comprehensive, illustrated instructions
Contents
Moulded ELAPOR® and ABS parts, all small items required,
Permax 400/6V motor, propeller, decals, instructions.
Specification
Wingspan 660 mm
Fuselage length 600 mm
Wing area approx. 13 dm²
Weight, standard approx. 450 g
Functions Aileron, elevator, throttle (delta-mix required)
ACCESSOIRES
PIECES DE RECHANGE
Page du catalogue 30
Teilesatz microJET weiss, im Kunststoffbeutel # 214202 * Prix: 49.90 €
* unv. Preisempfehlung inkl. deutscher MwSt.
