Afficher un message
Ancien 20/06/2007, 13h09   #1 (permalink)
mydo
Avatar de mydo
Inscrit : November 2006
Lieu: 41 VENDOME
voila c'est en anglais mais c'est mieux que rien :D
Directions – Brushless Motor Controller (ESC)
Thanks for using BP Brushless Motor Controllers. Please read the directions carefully before you start
to use new controllers.
Technical details:
Model Current (A) BEC Cells Weight (g)
MC10A 10 max 1A NiCd/NiMh 6-12
Li-Poly 2-3
14
MC20A 20 max 2A NiCd/NiMh 6-12
Li-Poly 2-3
20
MC30A 30 max 2A NiCd/NiMh 6-12
Li-Poly 2-3
25
MC40A 40 No NiCd/NiMh 6-18
Li-Poly 2-5
52
MC60A 60 No NiCd/NiMh 6-18
Li-Poly 2-5
55
MC80A 80 No NiCd/NiMh 6-18
Li-Poly 2-5
55
MC120A 120 No NiCd/NiMh 6-18
Li-Poly 2-5
75
Diagram for FM10A, FM20A, FM30A
Diagram For FM40A, FM60A, FM80A, FM120A
Main functions:
1. Safety mode: the motor won’t start no matter what the position of the control stick is when
switched on the RC unit.
2. Brake: On / Off (factory setting is Off)
3. Battery type: NiCd/NiMh, LiPoly (the setting of battery type must be done every time when
changing a battery pack)
4. Number of batteries: automatic
5. Start up mode: Soft start up, Hard start up
6. Timing mode: Soft timing – for 2, 4, 6 pole brushless motors, Hard timing – for 6 and more pole
motors, Auto
7. Temperature protection: the controllers have automatic reduce output power with auto detection
for temperature (120°C)
8. Low voltage protection: reduce output power when the voltage goes down
Operating instructions:
-Normal start up:
Connect the controller and motor as above connection drawing. Switch on the transmitter and check the
throttle stick is at low position. Connect the main power pack and switch on BEC (for the controllers with
BEC), you should hear a piece of music. After the music, you can begin flying. If the throttle stick is not
at low position, you will hear beeps from the motor, that alarms you moving the stick to low position.
-Setting:
Connect controller with motor as above connection diagram. Switch on the transmitter and check the
throttle stick is at high position. Connect the main power pack and switch on BEC (for the controllers
with BEC). After a piece of music, you can follow the prompting sound to begin programming. When
hear a prompting sound (sound 3 times), move the throttle stick from high to low position quickly. You
should hear a ‘beep’, your setting is done. Move the stick back to high position, waiting for the
prompting sound and repeat above steps for other settings. After your setting, keep the stick at low
position for 5 seconds, you will hear a piece of music. Now, you can begin flying.
Prompting Sound:
1. Brake Off: - - - - - -
2. Brake On: - - -
3. NiCd / NiMh: .- .- .-
4. LiPoly: .-- .-- .—
5. Soft Start up: ..- ..- ..-
6. Hard Start up: ..- - ..- - ..- -
7. Soft Timing: … - … - … -
8. Hard Timing: … - - … - - … - -
9. Reset to Factory Setting: .... .... ....
The controllers are supplied with factory setting, Brake Off, LiPoly (automatic for battery number),
Soft start up and Auto timing.
Programming Card:
Super series ESC can be programmed by a E-PRO programming card. It will expand ESC’s functions and
suitability. Details please see the instructions of SUPER E-PRO Programming Card.
Notice:
1. Choose suitable brushless motors and propellers, ensure the working current never exceed specified
current of ESC.
2. Make sure the connection for battery positive and negative is right. Reversing the connection will
damage the ESC permanently.
3. Use suitable batteries, do not exceed specified voltage of ESC.
4. Do not disassemble the ESC by self, it will damage the ESC or lose message.
5. The ESCs are designed for airplane models only.
6. Take care in using safely. Incorrect use may cause injury to the body. The company will not be
responsible for any damage or loss caused by incorrect operation.
7. Reverse the motor direction by exchanging the position of any two connections to the motor.
Warning:
The propellers on turning are dangerous. Disconnect the main power pack immediately after flying.
DBY keeps the rights to change design, function or package, without notice
mydo est déconnecté
Répondre en citant
