| | #1 (permalink) |
| Membre Sénior Inscrit : April 2004 Lieu: Bourg-en-Bresse (01)
| je ne retrouve plus le post de kallem qui annonçait la sortie en 2008 d'une nouvelle version de la Microjet de Multiplex (plus rapide!!! ;) ) Est-ce que c'est cette référence : #214202 ??? car pour moi c'est juste qu'elle est blanche et vendue en sachet plastique??? Merci et A+ ![]() Teilesatz microJET weiss, im Kunststoffbeutel #214202 -------------------------------------------------------------------------------- ELAPOR foamparts set complete This is the hot jet for the advanced model pilot. Due to the model’s size, its roll rate and general agility are extreme, setting new standards in terms of fun per pound. Nevertheless, the aeroplane’s flying characteristics are nicely balanced and the handling excellent. The micro-JET is supplied virtually as a one-piece model; only the fi ns and cabin are supplied separately, together with the landing guard and motor cover. The two Nano-S servos are simply inserted into the servo wells and secured with a drop of glue, while the control surfaces feature integral moulded hinges. • Supplied with white moulded parts • No painting required • Tough ELAPOR® moulded foam components • Vacuum-moulded parts to protect fuselage bottom and servos • Canopy-Lock canopy latch • Multi-colour decal sheet • All small parts required • Comprehensive, illustrated instructions Contents Moulded ELAPOR® and ABS parts, all small items required, Permax 400/6V motor, propeller, decals, instructions. Specification Wingspan 660 mm Fuselage length 600 mm Wing area approx. 13 dm² Weight, standard approx. 450 g Functions Aileron, elevator, throttle (delta-mix required) ACCESSOIRES PIECES DE RECHANGE Page du catalogue 30 -------------------------------------------------------------------------------- Teilesatz microJET weiss, im Kunststoffbeutel # 214202 * Prix: 49.90 € * unv. Preisempfehlung inkl. deutscher MwSt.
__________________ Sebsoupe _____________________________________________ http://www.casseursdepub.org/index.php?menu=campagnes VENDS chargeur Graupner LipoCharger4 http://forum.modelisme.com/t132256-v...ec-cg-207.html |
| | #2 (permalink) |
| Le petit nouveau Inscrit : March 2004 Lieu: 44/17/85
| Oui, c'est ça. Oui elle est blanche, et nettement plus rigide que l'ancienne. Avec un petit moteur de 300W dans le cul tu doubles les soit disants "rapides" Funjets avec 700W au premier virage......... :D Kallem
__________________ Cet espace est à louer........... ![]() |
| | #3 (permalink) | |
| Citation:
ça tombe bien, je l'ai commandé cet aprèm' chez AndyHobbyShop pour solder le reliquat d'une précédente commande qui avait mal tourné!!! et j'ai "en stock" un Align BL430L 3150 et des lipo 3S 2200... http://www.bungymania.com/imageshome/includes3/motorperf1.php?id=6&SELECT=funjet ça devrait bien marcher j'espère!!! (sauf s'il y a mieux et moins cher comme motorisation ;) ) Merci et A+
__________________ Sebsoupe _____________________________________________ http://www.casseursdepub.org/index.php?menu=campagnes VENDS chargeur Graupner LipoCharger4 http://forum.modelisme.com/t132256-v...ec-cg-207.html | |
| | #5 (permalink) |
| Aéromodelomaniac | Salut, Je ne la trouve pas sous cette référence sur le site de Andy... Tu l'as contacté directement?
__________________ Mes vidéos d'aéromodélisme: http://fr.youtube.com/user/stf650 Twinstar II FPV Fatshark, Acromaster, Funjet, Funcub+flotteur, Pitts 12 15e eflite, Bae Kawk EDF fibre, Rafale HET 2xEDF, Eagle EPP, Corsaire F4U TW748, Extra 300 HC, Evolution 60 BHL, Progress EPP Donuts, Hoverjet HK, Blade MCPX, et X² dépronades... MX16S, Eurgle 9ch 2.4gh, Spectrum Dx5e. |
| | #6 (permalink) |
| Membre Sénior Inscrit : February 2003 Lieu: Pres de Perpignan
| bonjours à tous ,je sais pas quel magasin ou je pourrais trouver ce nouveau microjet un magasin serieux de la vente par correspondance ,car j ai fait quelques recherches et je trouve rien en France ,à+,Claude
__________________ VENEZ VOIR MON BLOG http://claudius66.canalblog.com/ ET N ESITEZ PAS A FAIRE DES COMMANTAIRES |
| | #7 (permalink) | |||
| Citation:
[HS] : j'espère que c'est ma dernière commande chez Andy Hobby Shop, car si leurs prix sont intéressants, le manque de gestion du stock et la communication par mail pour obtenir des infos et passer commande (en donnant les n° de CB par mail :o ) ne m'a valu que des problèmes à chaque commande!!! :mad:
__________________ Sebsoupe _____________________________________________ http://www.casseursdepub.org/index.php?menu=campagnes VENDS chargeur Graupner LipoCharger4 http://forum.modelisme.com/t132256-v...ec-cg-207.html | |||
| | #8 (permalink) |
| Merci Sebsoupe je viens d en commander un ,mon Funjet a morfler raison pour le changer avec le meme matos light (a voir sur mon blog)mais justement environ 250w sa devrais donc donner car il doit etre plus leger ,je me demande quelle modif Multiplex a du faire par rapport à l anciene vertion?à+,Claude
| | #9 (permalink) | |
| Citation:
Kallem
__________________ Cet espace est à louer........... ![]() | |
| | #10 (permalink) |
| Ils auraient dû la faire rouge, c'est connu que ça va plus vite de cette couleur!!! ;) kallem, c'est le "nouvel" Elapor comme celui du Blizzard? est-ce qu'il y a encore les picots de moulage ou non ? Merci et A+
| Inscription |
Fuseau horaire : GMT +1. Il est 06h59.
