| | #1 (permalink) |
| Nouveau membre Inscrit : July 2010 Lieu: saint louis (alsace haut rhin)
| je recherche un gee bee en epo de 1m d'envergure voir plus !il y a celui de lanyu (sympa en noir et jaune )mais introuvable !! il y a le r3 de r2fly mais vendue quand RTF!! un ptit coup de pouce ! merci et bon vol
__________________ jet:amx jpower 64mn,mig 15 ,f4 phantom 70mn;f5 tiger 64 mn,alpha jet 64mn,stryker f27 Q parkzone?f15 avion hélice: mustang p51,p 47 thunderbolt 47 parkzone ,pitts s12 hobbyking, p38 lightning j-power,corsair f4u lanyu ,micro gee bee planeur:fox ,dg 1000 t2m |
| | #2 (permalink) |
| Membre actif Inscrit : March 2011 Lieu: Béziers 34500
| Il y a ça chez HK, un poil petit, envergure 900mm: HobbyKing R/C Hobby Store : GeeBee R2 EPO Plug-n-Fly (Brushless Rev 2) Dispo en France pour 59 euros ici, en 2 coloris: http://helicoracing.com/epages/box70...roducts/ar0654 EDIT j'ai commandé la version noire et jaune je met ici ce que j'ai trouvé comme set up recommandé par un utilisateur américian: This is a cool plane! At first I was like oh yeah not bad, but then I changed the power system from a 700kv motor and 11.4,7 SF prop to a 750kv motor and 11x7 SF prop and this is now SAWEEEEET!!!! I bought the kit from Aerialhobby and thought I was getting the orange and white one but when I opened the box I got the yellow and black one. No matter as it still looked great and besides I didn't have a yellow plane ![]() The build was relatively simple, the EPO foam is good and the power system I chose for it and installed, is the same as the Art-tech/Hobbyking Pitts is PERFECT and went in relatively easily. I had to use this stick motor mount which was fine and there's plenty of room behind the cowl to work with. The plane flies VERY nice, glides quite well(better than the Pitts) and is easy to practice your knife edges. The wheel pants and landing gear are a bit weak and I had to epoxy them on for strength. This will also nose over EVERY time on grass and everytime on anything other than a total perfect greased landing on bitumen runway. Alot of people remove em(wheel pants) but I think it wouldn't bee a GEEBEE without em I added a bunch of stickers and pilots head to it to try and make it look cooler tooWith the power system I'm running I get a 1:1 thrust ratio and over 200watts or power for under 20Amps. I use a 25amp hobbyking SS esc and 11x7 SF prop. Excellent setup for this plane
__________________ Radio SPEKTRUM dx6i Gee Bee 39" Wood&Fiberglass Graupner TAXI CUP 2 HK450 GT PRO BD/HK450 GT PRO TT E-sky King3 alu upgrade Deep-vee Arowana Mono 22.5" Catamaran Swordfish Nincocean 17" Gecko MHZ 13.5" Dernière modification de papyboyington34, 06/11/2011 à 23h30 |
| | #3 (permalink) |
| tu a commandé ton gee bee en france ouchez hobby king ? tu la déjà reçu ? pour moi !!pas moyen dans trouver un rupture de stock!!chez hobby king safait au moins 2 mois qu'il n'en vente plus ! je me demande s'il est encore dispo !! par contre un autre site chinois le propose !! R2hobbies.com - 4 Channel RC EP 35.4" Aerobatic GeeBee EPO Foamy ARF Scale Plane, ARF, rcpl51040_epo_arf_code je possède d'ailleurs le moteur et contro qui est conseillé ! récupéré sur deux ancien modêles arttech (corsair et pitts )
| | #4 (permalink) |
| J'ai commandé en France chez hélicoracing, la semaine dernière, livré en 3 jours, reçu mercredi dernier. Il leur reste un gee bee rouge et blanc en stock(vérifié ce matin). Pour le moteur j'ai commandé un outrunner 2828 1400kv pour le faire tourner en direct drive et en 2s.
__________________ Radio SPEKTRUM dx6i Gee Bee 39" Wood&Fiberglass Graupner TAXI CUP 2 HK450 GT PRO BD/HK450 GT PRO TT E-sky King3 alu upgrade Deep-vee Arowana Mono 22.5" Catamaran Swordfish Nincocean 17" Gecko MHZ 13.5" Dernière modification de papyboyington34, 14/11/2011 à 10h24 |
| | #5 (permalink) |
| J'ai bien eu le temps de faire voler mon gee bee Lanyu en 2s et en 3s. Le 2s n'est vraiment pas suffisant avec le kv que j'avais choisi, le gee bee n'aime pas trop les vols lents surtout a l'atterrissage. En 3s c'est carrément super, bien rapide, il réagit beaucoup mieux a la dérve et a la profondeur (qui sont assez petites). Il faut virer les carénages de roue qui sont au ras du sol, sur l'herbe c'est la gamelle assurée au décollage comme a l’atterrissage, la corde a piano du train étant assez souple les roues doivent être déplacées devant l'aile cela facilitera ces 2 manoeuvres. il est assez difficile de voir dans quel sens il est si l'on s'éloigne trop, 90cm d'envergure c'est peu, son fuselage court y est aussi pour beaucoup. Comme sur (presque) tous les gee bee l'atterrissage doit se faire avec un peu de vitesse sinon la dérive et la profondeur ne répondent pas assez et l'avion se retrouve direct sur le nez. Bref c'est un avion assez sympa et facile si l'on prend ces quelques précautions.
__________________ Radio SPEKTRUM dx6i Gee Bee 39" Wood&Fiberglass Graupner TAXI CUP 2 HK450 GT PRO BD/HK450 GT PRO TT E-sky King3 alu upgrade Deep-vee Arowana Mono 22.5" Catamaran Swordfish Nincocean 17" Gecko MHZ 13.5" |
| | #7 (permalink) |
| C'est le Gee Bee r3, il ne fait pas partie de la famille Gee bee au sens ou il n'a pas été conçu par les frères Grandvilles, il n'a jamais été fabriqué grandeur nature, c'est un designer récent qui l'a crée il y a quelques années. Ceci mis a part c'est un trés bel avion, il me tente bien lui aussi et deviens difficile a trouver, normalement c'est Donuts qui possède les droits de commercialisation. Tu l'as trouvé ou celui ci ?
Sujets similaires | ||||
| [AIDE] A la recherche du bon avion pour débuter de zéro | Zepiii | Aéro / Electrique | 59 | 01/08/2011 21h49 |
| Recherche pieces plastiques qui se fixent sur les ailes.. | Darkdjack | Aéro / Avions | 4 | 27/06/2011 07h51 |
| Recherche ancien numéro de MVM n°15 | Manu193 | Aéro / Discussions | 2 | 19/05/2011 15h19 |
| [Débutant] Recherche Controleur Phoenix rc | BoB.by | Aéro / Simulation | 0 | 10/04/2011 19h11 |
| [Construction] Recherche collaborateur-moniteur | BEN LADEN | Aéro / Construction | 1 | 20/03/2011 08h04 |
Fuseau horaire : GMT +1. Il est 03h53.
rupture de stock!!
