fluke
adversaries not enemies
voici le nouveau monster truck 1/10 de kyosho
selon la description c'est une 1/10 mais avec les roues de la st-rr!
Available: September 2010
Features
Contents:
What is a Ready Set?
Readyset is a fully assembled model that includes nearly everything you need to run. Body Color scheme is complete so only consumables like batteries and 7.4v Lipo/7.2-8.4v NiMh are required so you can start operating the model without delay.
Required For Operation:
AA- Batteries x8
7.2NiMh Stick Pack (3300mAh or higher) w dean plugs
2S- 1P Lipo with deans plugs
Proper charger for proper type of battery
30843B - $635.99
Features
- Full Time 4WD - The full-time 4WD chassis incorporates all of Kyosho’s formidable resources and know-how in the development of this low center of gravity shaft-driven 3-differential drive train.
- EZ Mesh - ORION VORTEX 10 brushless motor is pre-fitted on an aluminum die cast motor mount and allows gear backlash to be easily adjusted by just three screws.
- NiMH or LiPo - Can be used with either a 7.2-8.4V NiMH or 7.4V Lipo battery. Release the throttle and switch the power on to complete auto setup.
- Interchangeable - Ball connected suspension features interchangeable suspension arms, front-rear knuckles and shock stays for optimal parts utilization and maintenance efficiency.
- Double Wishbone Sus. - Double wishbone 4-wheel independent suspension with long span arms delivers excellent handling from paved to off-road surfaces.
- High Grip Tires - High grip tires and the same wheels proven on the INFERNO ST-RR allow you to dominate any running surface. The wheels are also compatible with a wide variety of after market tires.
- Big Bore Shocks - Features heavy duty big bore oil shocks as standard. Takes even the harshest punishment for long periods without complaint and provides excellent damping power.
- Pre Painted Body - Pre-painted so you can enjoy the action in true truck style without delay.
- HD Ring & Pinion - Precision machine cut diff ring gear provides extra strength and hardness.
- Adjustable ESC - ESC settings can be adjusted with an optional digital setup box.
- Multipoint Adjustments - Design features multi-point setting adjustments such as chassis height, camber, tread, front and rear toe-in etc.
- Shaft Drive - The drive shafts run through the center for chassis to give you better lower CG and optimum weight balance.
- New Steering Layout - The DMT VE has a whole new steering layout which gives you greater response and much more of a steering angle.
- Aluminum Motor Mount - Equipped with a black aluminum motor mount to secure the 540 Size Orion BL motor.
Contents:
- Pre-Assembled Chassis
- Pre-Painted Body
- Team Orion Vortex 10 B/L Motor
- Team Orion Vortex 10 MT
- Perfex KT6 Transmitter and RC System
- L Hex Wrench
- Cross Wrench
AA- Batteries x8
30843B - $635.99
