RcCar89
Car Bashing
Pour les anciens qui ont connu la mythique Kyosho Optima de 1985, Kyosho va re-sortir l'Optima avec quelques améliorations pour qu'elle puisse supporter un moteur brushless.
Nouveautés du chassis :
Plus d'infos et de photo ici : http://reports.kyoshoeurope.com/legendary-series-optima-toutes-les-photos/
D'après le site kyosho USA le prix serait de 299,99$ environ le même prix en euros sans doute.
Kyosho Europa à dit:New features :
1.) Chassis : All plates and the main chassis bars are now 6061T6 aluminum(counter sunk).
Aluminum chassis bars are slightly thicker for more durability.
2.) Drive-train : Kit includes both chain and belt drive trains allowing use of more powerful motors.
Diff gears now have ball bearings installed.
3.) Gears : Now in 48 pitch gears. Sintered alloy gears combined with high impact nylon gears and
newly added slipper clutch will cope with the current power plants.
4.) Shocks : New 10mm diameter aluminum cylinder with SUS shaft allows improved damping.
5.) Tires / Wheels : Slightly modified tread designs and new softer compound for superior grip and
handling. Rear tires include inner sponge. New 1 piece wheel design.
6.) 2 Types of bumpers included(Wide and Narrow)
7.) Aluminum motor guard.
8.) Updated geometry
9.) Hardware : All Hex
10.) Updated servo fixture
11.) Driver : Molded helmet design.
12.) Option Parts : We will release various option parts.
14.) Electronics compatibility : Compatible with the current standard servos,
Receiver units, ESCs, motors and battery packs.
15.) Packaging : Similar to the original with blister pack showing some of the parts included. Some
parts will be preassembled and parts will be bagged in steps following the instruction manual for easy
assembly.
