Glovepie ne peut-il pas aider en montrant les valeurs reçues du Nunchuck ?
http://wiipiicii.blogspot.com/2006/12/glovepie-intgration-du-nunchuk.html
Phil.
Phil.
#include <Wire.h>
#include <string.h>
#undef int
#include <stdio.h>
uint8_t outbuf[6]; // array to store arduino output
int cnt = 0;
int ledPin = 13;
int ledPin1 = 11; // Led broche digital PWM 11 pour visualisation du signal
int nouvelleValeur = 0;
void
setup ()
beginSerial (9600);
Serial.print ("Finished setup\n");
Wire.begin (); // join i2c bus with address 0x52
nunchuck_init (); // send the initilization handshake
pinMode(ledPin1, OUTPUT); // configure broche 11 en sortie
void
nunchuck_init ()
Wire.beginTransmission (0x52); // transmit to device 0x52
Wire.send (0x40); // sends memory address
Wire.send (0x00); // sends sent a zero.
Wire.endTransmission (); // stop transmitting
void
send_zero ()
Wire.send (0x00); // sends one byte
void
loop ()
Wire.requestFrom (0x52, 6); // request data from nunchuck
while (Wire.available ())
outbuf[cnt] = nunchuk_decode_byte (Wire.receive ()); // receive byte as an integer
digitalWrite (ledPin, HIGH); // sets the LED on
cnt++;
// If we recieved the 6 bytes, then go print them
if (cnt >= 5)
print ();
cnt = 0;
send_zero (); // send the request for next bytes
delay (100);
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits. That is why I
// multiply them by 2 * 2
void
print ()
int joy_x_axis = outbuf[0];
int joy_y_axis = outbuf[1];
int accel_x_axis = outbuf[2] * 2 * 2;
int accel_y_axis = outbuf[3] * 2 * 2;
int accel_z_axis = outbuf[4] * 2 * 2;
int z_button = 0;
int c_button = 0;
// byte outbuf[5] contains bits for z and c buttons
// it also contains the least significant bits for the accelerometer data
// so we have to check each bit of byte outbuf[5]
if ((outbuf[5] >> 0) & 1)
z_button = 1;
if ((outbuf[5] >> 1) & 1)
c_button = 1;
if ((outbuf[5] >> 2) & 1)
accel_x_axis += 2;
if ((outbuf[5] >> 3) & 1)
accel_x_axis += 1;
if ((outbuf[5] >> 4) & 1)
accel_y_axis += 2;
if ((outbuf[5] >> 5) & 1)
accel_y_axis += 1;
if ((outbuf[5] >> 6) & 1)
accel_z_axis += 2;
if ((outbuf[5] >> 7) & 1)
accel_z_axis += 1;
Serial.print("Axe x : ");
Serial.print (accel_x_axis, DEC);
Serial.print("/");
Serial.print(accel_x_axis/2);
Serial.print ("\t");
Serial.print("Axe y : ");
Serial.print (accel_y_axis, DEC);
Serial.print("/");
valeurRetour = accel_y_axis/2;
Serial.print (valeurRetour) ;
Serial.print ("\r\n");
analogWrite(ledPin1, valeurRetour) ;
// Encode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
char
nunchuk_decode_byte (char x)
x = (x ^ 0x17) + 0x17;
return x;
