ok voici la réponse j'ai trouvé
si vous avez d'autres a ajouter .....
Minimum requirements
There is one must requirement that is Android 4.0 or up.
You also need to have the Google Play Services library installed (it's already installed in most android devices). A good way to check this is by seeing if you can run the Google maps app.
You will need USB host also if you want to use a 3DR telemetry module directly, without USB you still can use a Bluetooth or TCP/UDP connection.
I use a 7 inch tablet for development, so I would suggest you get one that is at least this size.
List of know compatible devices
Here is a list of Android device know to have compatibility with DroidPlanner:
Dell Venue 7
Dell Venue 8
Google Nexus 5
Nexus 7 (2013) - This is our reference tablet
Google Nexus 7 (2012)
Tablet Genesis GT-7230
T-pad tablet IS701/IS709C
Asus TF300T and TF300TG - I don't recommend the 300T as the GPS is truly lousy....BUT is does run droidplanner.
Asus TF101 (original transformer tab)
Galaxy Note 10.1 With RFD900
Samsung Galaxy Note 2
Samsung Galaxy Note 3 with xBee 2.4GHz
Samsung Galaxy Tab 2 7.0 (GT-P3113)
Samsung Galaxy Tab 3 8.0 T310 - micro USB, needs adapter
Samsung Galaxy Tab 10.1 (GT-P7500)
Samsung Galaxy Note 10.1 (2014 edition) (SM-P601)
Samsung Galaxy S3 - micro USB, needs adapter
Samsung Galaxy S4 - micro USB, needs adapter
Samsung Galaxy Nexus
Xperia Z
Xperia Z1
Xperia Z1 Compact
Xperia Ultra (C6802)
A13 tablet (cheapes at deal extreem)
Acer Iconia A510
Acer Iconia A500/A501 - 10" tablet, full size USB port, no adapter needed
Asus Memo Pad 7 - OTG cable with power needed and rooted kernal with USB Host Diagnostics app
Asus Fonepad 7 (ME372CG)
iview 754TPCII - comes with OTG cable. Works out of the box.
hisense sero 7 Pro - needs rooted kernal
chinese V30 VIA WM8880 1.5GHz 7 inch Tablet PC Android 4.2 Dual Core Capacitive Touch Screen 800*480 512MB/4GB . Full size usb host port, work great out of the box.
Huawei MedaiPad 7 via OTG cable. NOT rooted, Works perfectly.
kobo Arc 10HD - works out of the box with 3DR usb cable
Lenovo A8-50 A5500 $139 on Amazon, you will need OTG cable from 3dr for telemetry to work, the blue connection goes toward the tablet
Archos 80 Cobalt - need OTG cable and rooting.
If your phone usb connection doesn't work you can try this out: Usbhostcheck
