patrice100574
jai acheté un variateur un moteur sur un site internet en asie tres connu.
le variateur c'est Turnigy Brushless ESC 85A w/ 5A SBEC , le moteur c'est NTM Prop Drive Series 35-48A 1100kv / 640w, la carte de programmation de mon variateur ou esc c'est Turnigy Programming card for Tz85A ESC. tout acheté sur le meme site..
sur le descriptif de l'esc , je vous le met.
Built with imported N-Channel mosFET's and an ultra fast Atmel MCU & heartbeat make this a high performance ESC with excellent sync capabilities. This ESC has a 5A SBEC for solid reliable servo power.
Programmable via an R/C controller.It allows you to program all functions to fit your specific needs, which makes it efficient and user friendly.
Features:
Extremely low internal resistance
Super smooth and accurate throttle linearity
Over heat and over-load protection
Auto shut down when signal is lost or radio interference becomes severe for more than 2 seconds
Supports high RPM motors
Power arming protection (prevents the motor from accidentally running when switched ON)
New Advanced programming software
Programming features:
Brake setting (we recommend using brake for only folding props applications)
Battery type(LiPo or NiCd/NiMh)
Low voltage cutoff setting
Factory default setup restore
Timing settings (to enhance ESC efficiency and smoothness)
Soft acceleration start ups (for delicate gearbox and helicopter applications)
Governor mode(for helicopter applications)
Motor rotation( clockwise\counterclockwise)
Switching frequency
Low voltage cutoff type (power reduction orirnmediate shutdown)
Factory default settings:
Brake: off
Battery type Detect: LiPo with Automatic Cell
Low voltage cutoff threshold: Medium (3.0V/65%)
Timing setup: Automatic
Soft Acceleration Start Up: Medium
Governor mode : OFF
Frequency : 8kHz
Low voltage cutoff type: Reduce power
Spec.
Cont. Current: 85A
Burst Current: 100A
Battery: 2-6 Cell Lipo / 5-18 Cell Ni-XX
SBEC: 5.5V/ 5A Output
Weight: 89g
ON voit bien qu'il ya cette phrase ""Motor rotation( clockwise\counterclockwise) ,
Donc pour moi ce variateur devrais faire la marche avant et la marche arriere.
Est ce que jai mal fait ma programmation?
sur la carte de programmation sur la 7 eme ligne, c'est marqué moteur reverse et comme choix 1 forward et 2 reverse.
jai choisi reverse. mais pas toujours de marche avat et arriere.
je fais mes teste avec le
Features:
Switching frequency
Brake: off
Governor mode : OFF
Frequency : 8kHz
Spec.
Cont. Current: 85A
Burst Current: 100A
Weight: 89g
Le testeur de servo ST-V2
Merci de maider a trouver la solution.
