J' ai un SKYRC IMax B8, excellent ce chargeur qui sait tout faire avec n' importe quel type d' accus
- Operating Voltage Range: 10.0~18.0 Volt
- Circuit Power: Max. 150W
- Charge Current Range: 0.1~7.0A
- Discharge Current Range: 0.1~5.0A
- Current Drain for Balancing Li-Po: 300mAh/cell
- NiCd/NiMH Battery Cell Count: 1~27 cells
- Lithium Battery Cell Count: 1~8 Series
- Pb Battery Voltage: 2 to 36 V
- Microprocessor controlled
- Delta-peak sensitivity
- Individual cell balancing
- Li-ion, LiPo and LiFe capable
- Ni-Cd and NiMH capable
- Large range of charge currents
- Store function, allows safe storage current
- Time limit function
- Input voltage monitoring. (Protects car batteries at the field)
- Data storage (Store up to 5 packs in memory)
- Battery break in and cycling.
- PC analysis via USB cable (software & USB not included)
- Weight: 574g
- Dimension: 170mm X 110mm X 35mm
Je l' ai paye 55 €uros via Ebay sinon il est a 175 €uros en mag...
