hitec aurora + frsky delta 8 failsafe????
moncef38
Bonjour,je vais tester ce fameux delta 8 qui a l'air pas mal,je voudrais savoir si on peux programmer un failsafe avec une aurora
avez vous des avis sur ce récepteur?
merci
Setting the Failsafe
1 Ensure that the transmitter and receiver are both switched on and linked first.
2 Move all controls to the desired positions that you wish to set the Failsafe too.
3 Push and hold the receiver button for 5 seconds.
4 The Red LED will flash rapidly for a short period to indicate that the Failsafe has been set.
��To disable the Failsafe, re‐link the receiver.
��If your transmitter has a Failsafe facility, this will not take effect. It is recommended to disable the transmitter Failsafe to prevent any conflict.
kallem;2394202 à dit:
merci pour ta réponse,
tu l'a déja tester ce récepteur?
