OpenXsensor : Librairies télémesures FR Sky, Multiplex, Jeti, Hott
Thyzoon
Je trouvé ça : OpenXsensor :
https://openxsensor.github.io/
https://github.com/openXsensor/openXsensor
C'est un ensemble de bibliothèques pour Arduino compatibles FR Sky, Multiplex, Jeti, Graupner Hott.
It is compatible with :
  • The Multiplex receivers
  • The Frsky receivers : D series (HUB protocol) and X series (Smart Port protocol)
  • The Graupner receivers (Hott protocol)
  • The Jeti receivers (EX protocol only)
##Functionalities provided at your choice :##
  • Altimeter / Variometer
    • Uses normally a MS5611 sensor (GY-63 or GY-86 module)
    • Alternatives: a BMP085, a BMP180 or a BMP280 sensor can be used as first sensor
    • A second barometric sensor can be added
    • Possibility to change vario sensitivity and/or to switch between 2 vertical speeds from TX while flying
  • Air Speed
    • Uses normally a 4525DO-DS5AI001DP sensor
    • Alternative: ADS1115 + MPXV7002DP (not tested yet)
    • Can also be used by oXs to compensate vertical speed measurements (dTE)
  • GPS
    • Can be connected to a GPS (UBLOX NEO6/NEO7/NEO8) and transmit collected data
  • Accelerometer/gyroscope
    • Can be connected to a MPU6050 sensor (e.g. GY-86 module that have a baro sensor too)
    • Can calculate vertical speed based on accelerations + baro (faster reaction of vario)
    • Can calculate Roll and Pitch for attitude indicator (using a Lua script on OpenTx)
  • Up to 6 voltages measurements with Arduino
    • Battery voltage measurements
    • Lipo battery cell measurements
  • Up to 4 more accurate (and/or lower) voltages measurements with an extra ADC
    • Uses an ADS1115 module
    • Can be combined with Current and Airspeed sensor
  • RPM sensor
  • Current sensor
    • Max Amp depends on the sensor being used (e.g. ACS712, ACS754, ACS758)
    • Can calculate the consumed current
  • Can use any sensor outputting voltage to provide other data
    • Conversion from Volt to other units (e.g. to degree for temperature sensor)
    • Can be associate with termistor
  • Can calculate glider ratio to improve glider setup while flying
  • Can generate several sequences of signal (e.g. for light sequencer)
Thierry
Réponse assez tardive : Ce projet est génial ! :applouse:
Pour 30€ j'ai commandé il y a deux semaines de quoi fabriquer une télémétrie "Full options".
La suite : Dans un mois environ (commande en Chine ... Et ça arrive à pied de las bas :-D)
Christophe
