Bonjour
le câblage et le code (provisoire)
Yves
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <https://www.gnu.org/licenses/>.
Packet sniffer
Reçoit et décode les données émises par une balise et les affiche dans la console.
Fonctionne avec n'importe quelle carte à base ESP32 et
https://github.com/esp8266/Arduino
* ** Limitation du SDK : la trame ne peut être décodée en totalité (ID, LAT, LONG et AlT si ssid court) **
Bibliothéque
#include <Arduino.h>
#include <Wire.h> // Only needed for Arduino 1.6.5 and earlier
#include "SSD1306Ascii.h"
#include "SSD1306AsciiWire.h"
#include <user_interface.h>
ecran oled
#define I2C_ADDRESS 0x3C
SSD1306AsciiWire oled;
variable
int idbalise = 0;
int ecranacceuil = 0;
int incomingByte = 0;
extern "C" {
#define DATA_LENGTH 112
#define TYPE_MANAGEMENT 0x00
#define TYPE_CONTROL 0x01
#define TYPE_DATA 0x02
#define SUBTYPE_PROBE_REQUEST 0x04
struct RxControl {
signed rssi: 8; // signal intensity of packet
unsigned rate: 4;
unsigned is_group: 1;
unsigned: 1;
unsigned sig_mode: 2; // 0:is 11n packet; 1:is not 11n packet;
unsigned legacy_length: 12; // if not 11n packet, shows length of packet.
unsigned damatch0: 1;
unsigned damatch1: 1;
unsigned bssidmatch0: 1;
unsigned bssidmatch1: 1;
unsigned MCS: 7; // if is 11n packet, shows the modulation and code used (range from 0 to 76)
unsigned CWB: 1; // if is 11n packet, shows if is HT40 packet or not
unsigned HT_length: 16; // if is 11n packet, shows length of packet.
unsigned Smoothing: 1;
unsigned Not_Sounding: 1;
unsigned: 1;
unsigned Aggregation: 1;
unsigned STBC: 2;
unsigned FEC_CODING: 1; // if is 11n packet, shows if is LDPC packet or not.
unsigned SGI: 1;
unsigned rxend_state: 8;
unsigned ampdu_cnt: 8;
unsigned channel: 6; //which channel this packet in.
unsigned: 12;
struct SnifferPacket {
struct RxControl rx_ctrl;
uint8_t data[DATA_LENGTH];
uint16_t cnt;
uint16_t len;
Enumeration des types de données à envoyer
enum DATA_TYPE : uint8_t {
RESERVED = 0,
PROTOCOL_VERSION = 1,
ID_FR = 2,
ID_ANSI_CTA = 3,
LATITUDE = 4, // In WS84 in degree * 1e5
LONGITUDE = 5, // In WS84 in degree * 1e5
ALTITUDE = 6, // In MSL in m
HEIGTH = 7, // From Home in m
HOME_LATITUDE = 8, // In WS84 in degree * 1e5
HOME_LONGITUDE = 9, // In WS84 in degree * 1e5
GROUND_SPEED = 10, // In m/s
HEADING = 11, // Heading in degree from north 0 to 359.
NOT_DEFINED_END = 12,
Tableau TLV (TYPE, LENGTH, VALUE) avec les tailles attendu des différents type données.
static constexpr uint8_t TLV_LENGTH[] {
0, // [DATA_TYPE::RESERVED]
1, // [DATA_TYPE:
ROTOCOL_VERSION]
30, // [DATA_TYPE::ID_FR]
0, // [DATA_TYPE::ID_ANSI_CTA]
4, // [DATA_TYPE::LATITUDE]
4, // [DATA_TYPE::LONGITUDE]
2, // [DATA_TYPE::ALTITUDE]
2, // [DATA_TYPE::HEIGTH]
4, // [DATA_TYPE::HOME_LATITUDE]
4, // [DATA_TYPE::HOME_LONGITUDE]
1, // [DATA_TYPE::GROUND_SPEED]
2, // [DATA_TYPE::HEADING]
void showMetadata(SnifferPacket *snifferPacket) {
unsigned int frameControl = ((unsigned int)snifferPacket->data[1] << 8) + snifferPacket->data[0];
uint8_t frameType = (frameControl & 0b0000000000001100) >> 2;
uint8_t frameSubType = (frameControl & 0b0000000011110000) >> 4;
uint8_t SSID_length = snifferPacket->data[40 - 4];
uint8_t offset_OUI = 41 - 4 + SSID_length + 1;
const uint8_t FRAME_OUI[3] = {0x6A, 0x5C, 0x35};
// Filter OUI from 6A:5C:35
if (snifferPacket->data[offset_OUI + 1] != FRAME_OUI[0] && snifferPacket->data[offset_OUI + 2] != FRAME_OUI[1] && snifferPacket->data[offset_OUI + 3] != FRAME_OUI[2])
return;
char addr[] = "00:00:00:00:00:00";
getMAC(addr, snifferPacket->data, 10);
// Informations supplémentaires
Serial.print(" RSSI: "); Serial.print(snifferPacket->rx_ctrl.rssi, DEC);
Serial.print(" Ch: "); Serial.print(wifi_get_channel());
//Serial.print(" MAC: "); Serial.print(addr);
Serial.print(" AP: "); printDataSpan(41 - 4, SSID_length, snifferPacket->data);
// ID balise
Serial.print(" ID: "); printDataSpan(offset_OUI + 4 + 6, TLV_LENGTH[ID_FR] , snifferPacket->data);
uint16_t offset = offset_OUI + 4 + 6 + TLV_LENGTH[ID_FR] + 2; // +2 : Type + Lenght
idbalise = (ID_FR);
// Latitude
Serial.print(" LAT: "); printCoordinatesLAT(offset, TLV_LENGTH[LATITUDE] , snifferPacket->data);
offset += TLV_LENGTH[LATITUDE] + 2;
// Longitude
Serial.print(" LON: "); printCoordinatesLONG(offset, TLV_LENGTH[LONGITUDE] , snifferPacket->data); //Serial.println();
offset += TLV_LENGTH[LONGITUDE] + 2;
//Altitude msl
Serial.print(" ALTmsl: "); printAltitude(offset, TLV_LENGTH[ALTITUDE] , snifferPacket->data); //Serial.println();
offset += TLV_LENGTH[ALTITUDE] + 2;
// Serial.print(" AltHome: "); printAltitude(offset, TLV_LENGTH[HEIGTH] , snifferPacket->data); //Serial.println();
offset += TLV_LENGTH[HEIGTH] + 2;
Serial.println();
Callback for promiscuous mode
void ICACHE_FLASH_ATTR sniffer_callback(uint8_t *buffer, uint16_t length) {
struct SnifferPacket *snifferPacket = (struct SnifferPacket*) buffer;
showMetadata(snifferPacket);
void printDataSpan(uint16_t start, uint16_t size, uint8_t* data) {
for (uint16_t i = start+10; i < DATA_LENGTH && i < start + size; i++) {
Serial.write(data
oled.write(data);
oled.println();
void printDataSpanID(uint16_t start, uint16_t size, uint8_t* data) {
for (uint16_t i = start; i < DATA_LENGTH && i < start + size; i++) {
Serial.write(data);
incomingByte = Serial.read();
void printCoordinatesLAT(uint16_t start, uint16_t size, uint8_t* data) {
uint8_t count = size - 1;
int data_value = 0;
//Serial.print(" data_value="); Serial.print(data_value); Serial.print(" neg=");
bool neg_number = data[start] > 0x7F;
//Serial.print(neg_number);Serial.print(" ");
//Serial.print(count); Serial.print("-");
data_value += (data) << (8 * count);
count--;
if (neg_number) {
data_value = (0xFFFFFFFF & ~data_value) + 1;
data_value *= -1;
Serial.print(double(data_value) * 0.00001 , 5);
oled.print( "LAT :");
oled.println( String(double(data_value) * 0.00001 , 5));
oled.println();
void printCoordinatesLONG(uint16_t start, uint16_t size, uint8_t* data) {
int data_value = 0;
count--;
if (neg_number) {
data_value *= -1;
oled.print( "LONG :");
oled.println();
void printAltitude(uint16_t start, uint16_t size, uint8_t* data) {
int data_value = 0;
count--;
if (neg_number) {
data_value = (0xFFFF & ~data_value) + 1;
data_value *= -1;
oled.print( "Altitude :");
oled.println(data_value);
void getMAC(char *addr, uint8_t* data, uint16_t offset) {
sprintf(addr, "%02x:%02x:%02x:%02x:%02x:%02x", data[offset + 0], data[offset + 1], data[offset + 2], data[offset + 3], data[offset + 4], data[offset + 5]);
#define DISABLE 0
#define ENABLE 1
void setup() {
// set the WiFi chip to "promiscuous" mode aka monitor mode
Serial.begin(115200);
Serial.print("début sniffer");
delay(10);
Wire.begin();
oled.begin(&Adafruit128x64, I2C_ADDRESS);
oled.setFont(Adafruit5x7);
oled.setScrollMode(SCROLL_MODE_AUTO);
if (ecranacceuil == 0) {
affiche ();
wifi_set_opmode(STATION_MODE);
wifi_set_channel(6);
wifi_promiscuous_enable(DISABLE);
delay(10);
wifi_set_promiscuous_rx_cb(sniffer_callback);
delay(10);
wifi_promiscuous_enable(ENABLE);
void loop() {
void showMetadata(SnifferPacket * snifferPacket);
//void affichedata ();
delay(2000);
// oled.clear();
void affiche () {
oled.clear();
oled.set2X();
oled.println("SCANNER");
oled.setCursor(1, 200);
oled.print("BALISE DGAC");
delay(2000);
oled.clear();
oled.set1X();
else {
oled.clear();
ecranacceuil = 1;
void affichedata () {
oled.clear();
oled.set2X();
oled.println("id drone");
Serial.println("affichage data");
