fluke
adversaries not enemies
Team Associated has taken all of the refinements from the RC8.2 and have applied them to our electric-power platform-creating the RC8.2e Factory Team Kit! The RC8.2e has already been proven as a winner after TQing and winning the 2011 Sidewinder Nitro Explosion in the capable hands of Ryan Cavalieri.
The RC8.2e Factory Team Kit has a long list of new performance parts, making for the best and lightest Associated EP 1:8 scale buggy to date. The RC8.2e starts with the Factory Team +3mm 7075 hard anodized chassis. The new chassis and side-guards shed over half an ounce along with adding 3mm of length to optimize weight distribution and overall handling.
The RC8.2e Factory Team Kit also received the newly designed suspension arms featuring centerline shock mounts and an optimized anti-roll bar position. The new suspension arms were designed to work with the Factory Team 5mm 7075 aluminum low-center-of-gravity shock towers to improve and optimize the suspension geometry, making the RC8.2e more plush and forgiving in rougher terrain.
The RC8.2e Factory Team Kit includes the 16mm Big Bore hard-anodized threaded shocks with 4mm titanium-nitride coated shafts and revised shock boots, all to help increase traction and keep the rubber on the ground. The RC8.2e Factory Team Kit also proves to be an exceptional value, including many Factory Team parts that were previously only available as separately purchased upgrades.
Take your electric-powered 1:8 scale buggy game to the next level with the new RC8.2e Factory Team Kit, and drive what the winners drive!
Features
Factory Team blue aluminum sliding motor mount
Factory Team 3mm lengthened 7075 hard-anodized chassis
New suspension arms feature centerline shock mounts and optimized anti-roll bar position
Factory Team 16mm Big Bore hard-anodized threaded shocks with 4mm titanium-nitride coated shafts
Factory Team 5mm 7075 aluminum low-center-of-gravity shock towers with optimized geometry
Factory Team 7075 blue aluminum suspension mounts
Factory Team 7075 blue aluminum steering knuckles
Factory Team 7075 aluminum axles and center drives
Factory Team 7075 blue aluminum one-piece top plate
Factory Team lightweight ring gears
Factory Team lightweight diff outdrives
Factory Team aluminum steering posts
CVA boots on center and rear drive joints
New low-center-of-gravity wing mount
JConcepts Punisher Body and Illuzion wing included
Molded composite radio tray
Molded composite front and rear chassis braces
Tough steel-alloy shock standoffs
Factory Team 83mm "big" wheels included
Caster blocks adjust 14, 16, or 18 degrees with molded inserts
3.5mm light CVA drivetrain with full ball bearings
Factory Team shock and differential fluids included
