thatslife78
Hello.
Vu dans le manuel du RX : pas de fail safe a cette tension de 7.4 volts MAX :
*NOTICE (When Li-Po 2cell Battery, 7.4V is used.)*
Battery fail safe of transmitters except for M12, Exzes Z are set between 3.5V to 5.0V.
Therefore since the voltage of Li-Po Battery cannot be set, battery fail safe do not work.
If Li-Po battery is used, please check your driving time and replace battery safely.
We shall not be liable for any trouble about battery fail safe when Li-Po battery is used.
