Je m'étais lancé sur ce modele tête baissé et faute de patience, je laisse tomber...
Donc je vends mon HK450 et tout le stock de pieces que j'avais emmagasiné (en prévision de crashs et autre ...;-)
Le tout 150€
Description
Turnigy 450 H2218 Brushless outrunner 3550KV
HK450 CCPM 3D Helicopter Kit (Align T-rex Compat.) Ver. 2
HK450 size Pinion Gear 3.17mm/11T (Align part # HZ052)
Hobby King 401B AVCS Digital Head Lock Gyro
Turnigy R/C Helicopter Pitch Gauge
HobbyKing HK-922MG Digital Metal Gear Servo 1.8kg/ 12g/ 0.07sec
HK450 size Pinion Gear 3.17mm/13T (Align part # H45059)
325mm Fiber Glass Main Blades (1pair)
TURNIGY Plush 60amp Speed Controller
HK450 carbon tail boom
450 Size Heli Flybar Paddle White (pair)
450 Size Heli Yellow Plastic Tail Blade (pair)
HK450V2 Main Gear Assembly
Training Gear for 450 Class Helicopter
HK-450 Main rotor head assemply upgrade. (4MM FS)
TGY-306G-HV High Voltage Ultra Fast/High Torque MG Digital Alloy Cased Servo 3.7kg / .05sec / 21g
HK450V2 Linkage Rod Set
HK450V2 Metal Tail Rotor Assembly
HK450V2 Tail Drive Gear Set
HK450V2 Anti-Rotation Bracket
HK450V2 Stabilizer Blade
HK450V2 Metal Tail Boom Holder
HK450V2 CF horizontal/vertical tail fin
BLUE 6x Compatible T-rex 450 Metal Tail Boom 347mm
F-H45033 Metal Stabilizer Mount For T-Rex Trex 450 Pro
4pairs V2-233 Carbon Fiber Tail boom brace 227mm f Trex T
4x V2-127-W 450 Main Gear Set (W) for Trex T-rex 450 SE
4x Flybar Rod 220mm T-REX 450 SE V2/PRO/PORT HS1264 US
Ball Link Plier + 4 in 1 Hex Screwdriver Set 1.5/2.0/2.5/
4pairs 60mm REAL CARBON Fiber Tail Rotor Blade For T-REX
Le tout 150€
Description
