JE VEND LE KIT DU BATEAU JULES VERNE
ETAT NEUF
Graupner Jules Verne Motor Yacht 1:20 Scale Kit for Radio Control
The Graupner model of the Jules Verne was developed in conjunction with the Dutch designer Rene van der Velden. This is a "retro-look" motor yacht, and is similar in shape and colour scheme to the characteristic mahogany vessels constructed in the 1930´s and 40's.
The full-size Jules Verne was built in 1998, and combines in an ideal way the essential design elements of those earlier yachts with modern facilities andrefinements. The result is one of the most elegant yachts of the "retro-style" to be produced to date. For reasons of cost timber-built hulls are virtually never built nowadays, so the hull of the Jules Verne is made of aluminium and painted mahogany brown. The boat´s two engines, each rated at 660 BHP, endow it with a top speed of around 26 knots.
Our model of the Jules Verne is designed to a scale of 1:20, and is based on the designer's original drawings. It does call for certain manual skills and a modicum of experience in boat modelling, so the kit is only recommended to the experienced boatbuilder. All the rounded parts are vacuum-moulded in ABS, and the parts which normally present problems are also CNC-trimmed, including the hull, stern steps, deck and superstructure. The wooden parts are die-stamped in order to shorten the building time. The kit includes injection-moulded fittings such as windscreen wipers, ventilators, lamps, radar unit etc. as standard. The lamp housings in the fittings set can easily be made to work by fitting miniature 2.4 mm diameter filament bulbs.
Pack contents:
Quick-build plan, assembly instructions including RC installation notes in German, English and French. Vacuum-moulded CNC-trimmed parts including hull, deck, stern steps and superstructure; additional vacuum-moulded parts including inflatable boat, roof, cockpit, seats, tables, crane, hatches and other small items; printed and die-cut wooden parts, machined plywood handrails and mast components, strip material, tubing, rod and wire, decal sheet, complete fittings set, propeller shafts, propellers, motor mount, rudder systems and small parts.
RC functions:
Rudder
Proportional speed control (forward / reverse)
Bow thruster
Additional working systems may be installed at the builder´s discretion, e.g. lighting, rotating radar antenna etc.
Specification:
Length: 925 mm
Beam: 250 mm
All-up weight: 4.6 kg
Empty weight: 2.3 kg
Scale 1:20
Prix 230euro FDPC
ETAT NEUF
Pack contents:
RC functions:
Rudder
Bow thruster
Specification:
Length: 925 mm
Beam: 250 mm
Scale 1:20
Prix 230euro FDPC
