These days I have dedicated myself to the programming software of this 3-axis gyroscope, Aura 8. The "Aura config tool", (download free from the Flexinnovations) is really powerful, and if at first glance it may seem difficult to understand , trying to program the gyro it turns out that with patience you will get good results.
I would like to point one interesting aspect: with Aura 8 you can use a number of output channels as additional channels of Rx. I mean.
I state that I use the Jeti Duplex System 2.4 and that thanks to the availability of Michele Moschetta that a few months is the authorized dealer Jeti with the company MMD JetiItalia, I was able to deepen the knowledge of this remarkable system. I connected the Aura 8 to my receiver Jeti REX7 through port "B" of the gyro and the receiver output 7 with the protocol Jeti UDI interface (almost like an S-Bus Futaba) .To do this you need, however, access the parameters of Rx via the menu "Device Explorer" of the Jeti TX (I have the DS-16) and set the output Pin 7 (physical channel 7) not as a "servant" but "Serial UDI" (12 or 16 is irrelevant). In doing so not only can you connect the gyroscope (or other devices) via a single cable, but you can take advantage of as many as 16 output channels: 7 in the pin of Rx and others 9 virtual (total 16...). It 'simply assign the functions and the assignment to serve on Tx find them on the device (in my case the Aura 8). in doing so I was able to enjoy a total of 11 channels in my Rx 7 channels ... And all works fine!
