skirit;2487132 à dit:
I've already apologized for the mistake. I do not think it is a fatal error, the axis is shifted by 1.5 mm. The rudder can be installed so that the fault can not be seen and function are not affected. All customers so far managed without problem.
Pilatus has undergone a series of improvements. The frame fits, wing is stronger etc.
I'm sorry, but I consider it as a marginal issue.
Reactions from clients interested me, the evidence is that I watch on this forum.
Best regards
Petr KovaÅ™ík, royal-model
Dear Skirit ( Royal Model top management ? ), I am glad to read you here
As you said, it is not a fatal error... but the answer you gave me through Weymuller, yes it was
Maybe it is just a language problem, your appologize are maybe true but I cannot feel it as first approach
- I understood that you have produced 3000 glider like that.
Never did you think to improve it ?
- You said, that we can install as it is
Sorry but I tried and in my case, you are wrong ( you can see previous picture )
At least I have to move the rotation axis or I have to cut the fuselage ( rudder ) to be able to install it otherwise I have contact on the left and big gap on the right
- You said that nobody complain ( maybe to you ) but as you can find here, 2 spanish people modified the rudder ( 1 completely and 1 the fixation )
I would prefer to get answer from you which explain how to repair easily the mistake compare to your answer which suggest that I complain for nothing
Sorry I like when it is perfect
As I said, it is sad for both of us because I wanted to buy to you the FOX 2m20 but answer I received stopped this idea
Just to compare :
I bought extra 300 Pilot RC and got some small trouble with the frame kit
For each of these troubles, I received personal email from the Chinese president with countermeasure ( spare parts free of charge, instruction to solve the mistake, etc )
It is time now to continue the construction !
