Du nouveau chez hobbyking,
Pour 65$ (avec un buddycode) on peu avoir un réacteur pulse jet complet avec système de mise à feu.
http://www.hobbyking.com/hobbyking/...gine_34_Red_Head_34_with_Ignition_System.html
A quelles utilisations possibles vous fait penser cet engin ?
Personnellement je le verrais très bien dans un jet delta d'environ 2kilos.
Specs:
length: 550mm
Diameter: 64mm
Ports/Reeds: 10
Weight: 460grams
Thrust: 1.6 kilograms (3.52 lbs)
Fuel: gasoline (no oil required)
Ignition: external igniter box 20kv (only needed for starting)
Included:
Red head Pulse jet engine
Spare parts (to include reeds and spark plugs)
Mounting Clamps
20kv igniter
Required:
2~3 cell lipo with XT60 connector (for igniter)
Gasoline safe fuel tank and fuel line
Bicycle tire pump or other air source capable of 40psi (for starting)
Hearing protection
**Note: This is not a toy and gasoline is dangerous. Proper use and safety must be considered and exercised before, during and after use.
Specs:
length: 550mm
Diameter: 64mm
Ports/Reeds: 10
Weight: 460grams
Included:
Mounting Clamps
20kv igniter
Required:
Hearing protection
