#include <RcSeq.h>
#include <TinyPinChange.h>
#include <SoftRcPulseIn.h>
IMPORTANT:
For this sketch to compile, RC_SEQ_WITH_SOFT_RC_PULSE_IN_SUPPORT and RC_SEQ_WITH_SHORT_ACTION_SUPPORT shall be defined
in PathOfTheLibraries/(Digispark)RcSeq/RcSeq.h and RC_SEQ_WITH_SOFT_RC_PULSE_OUT_SUPPORT shall be commented.
This sketch demonstrates how to easily use a 3 positions switch on a channel of a RC Transmitter with <RcSeq> library.
1) If the switch is at the MIDDLE position, a LED will be OFF
2) If the switch is at the DOWN position, a LED will be ON
2) If the switch is at the UP position, a LED will blink
This sketch can be extended to a rotactor (up to 8 positions)
RC Navy (2013)
http://p.loussouarn.free.fr
WIRING A TRANSMITTER SIDE WIRING AT RECEIVER SIDE
| UP o # 4.7K | |
| \ # | ARDUINO or ATTINY |
3 positions | \ | | | R
switch < MIDDLE o o---+-------------> To Tx Channel Rx Channel->|RC_CHANNEL_PIN LED_PIN >----###---|>|----|GND
| C | | | LED
| # | Sketch |
| DOWN o # 4.7K '-------------------------' External or
\ | # Built-in LED
| Switch Pos | Pulse Width Range (us) | Action |
| UP | 1000 -> 1270 | LED Blinking |
| MIDDLE | 1360 -> 1630 | LED OFF |
| DOWN | 1720 -> 1990 | LED ON |
Note:
<RcSeq> computes automatically the valid pulse width range for each position of the switch.
/* Channel Declaration */
enum {RC_CHANNEL=0, RC_CHANNEL_NB}; /* Here, as there is a single channel, we could used a simple "#define RC_CHANNEL 0" rather an enumeration */
#define RC_CHANNEL_PIN 0 // Choose here the pin
#define LED_PIN 1 // Choose here the pin
enum {SW_POS_DOWN=0, SW_POS_MIDDLE, SW_POS_UP, SW_POS_NB}; /* Switch has 3 positions: Down, Middle and Up (For a rotactor with more positions, add positions here) */
boolean BlinkCmd=false;
boolean LedState=false;
void setup()
RcSeq_Init();
RcSeq_DeclareSignal(RC_CHANNEL, RC_CHANNEL_PIN); /* RC_CHANNEL Channel is assigned to RC_CHANNEL_PIN pin */
RcSeq_DeclareMultiPosSwitch(RC_CHANNEL, 1000, 2000, SW_POS_NB); /* Tells to <RcSeq> that the RC_CHANNEL channel has SW_POS_NB positions distributed between 1000 and 2000 us */
RcSeq_DeclareCommandAndShortAction(RC_CHANNEL, SW_POS_DOWN, ActionSwPosDown); /* Action assigned to DOWN position */
RcSeq_DeclareCommandAndShortAction(RC_CHANNEL, SW_POS_MIDDLE, ActionSwPosMiddle); /* Action assigned to MIDDLE position */
RcSeq_DeclareCommandAndShortAction(RC_CHANNEL, SW_POS_UP, ActionSwPosUp); /* Action assigned to UP position */
pinMode(LED_PIN, OUTPUT);
void loop()
static uint32_t StartMs=millis();
/* Refresh RcSeq (mandatory) */
RcSeq_Refresh();
/* Blink Management */
if( (BlinkCmd==true) && (millis() - StartMs >= 250UL) )
StartMs=millis();
LedState=!LedState;
digitalWrite(LED_PIN, LedState);
void ActionSwPosUp() /* This function will be called when the switch is in UP position */
BlinkCmd=true;
void ActionSwPosMiddle() /* This function will be called when the switch is in MIDDLE position */
BlinkCmd=false;
LedState=false;
void ActionSwPosDown() /* This function will be called when the switch is in DOWN position */
BlinkCmd=false;
LedState=true;
