Goldkinder
Voici les caractéristiques du modèle TYRANNOSAURUS (identique au ELDORADA)
RTR 4WD .18 JAPAN Engine GAS Off-ROAD TRUCK - TYRANNOSAURUS
FULL BALL BEARINGS ARE FREE AS BONUS!
THIS NEWEST 4-wheel drive off-road ready-to-run race truck style TYRANNOSAURUS w/.18 Vertex Engine Nitro Truck
This is a 1:10 scale unstoppable nitro power truck.
R/C 1:10 SCALE NITRO GAS 4WD RACING OFF-ROAD TRUCK FROM "HI SPEED" TYRANNOSAURUS WITH 18 Vertex ENGINE AND DURABLE BODY WHICH IS MORE RESIST TO CRASH THAN PVC BODY!!!
HIS BABY RUNS OVER 60MPH OFF-ROAD ON NITRO-FUEL GAS!!
• Length : 400mm( 14")
• Width : 310mm (12")
• Height : 185mm( 7.4")
• Wheelbase : 275mm (11")
• Round Clearance: 30mm
• Gear Ratio: 14.3:1
• Engine : .18 Vertex Engine
• Diameter of Wheel: 120 * 60 mm
• Thread : 150 mm
• PACKAGE INCLUDE:
(1) 1 x BRAND NEW .18 Vertex ENGINE
(2) 1 x 1:10 SCALE PAINTED LEXAN BODY CHASSIS
(3) QUALITY SPEED SPORT WHEEL RADIO CONTROL SYSTEM
(4) FULL ENGLISH MANUAL & WARRANTY
• Fuel tank with vast capacity, easily to refuel with super calibre, prevent overflowing and leaking
• Front/rear umbrella gear differential and differential box with leak protection
• With 13.8g super-light-weight fly wheel, make the engine smaller in load
• Adrustable-bounce, make spring buffered
• Differential with 5pcs of screw only, fixing/disasembling is easy
• The all-metal disc type brakes and super thick asbestos brake block
• Flexuose 6061 aluminum chassis, thickness:2.5mm
• Aluminum alloy in 6061, Anodic heavy-duty adrustor
• Variable shockproof spring
• Double sponge filter, dustproof result is better. 7.5mm oversize gas vent
• 56mm resonance
• 3 Steps Reducer
• Over Loading Protector
• Strengthen Rod on Shockproof
• Crashworthy Spring
• 8-pcs Super-long Suspension
• Six holes make air to be circumfluence, air-pressure more uniformity and less air bubble
• Easily to refuel with super calibre
• Bouding wall prevent leaking
• Carbon fibre up-plate
• All-metal oil pressure type shockproof device
• Byte ten universal drive shaft
• All-metal exhaust pipe
• Ball bearing for whole vehicle IS INSTALLED FOR BONUS!
• Exhausting backward engine (need to match platform starter or bacilliform starter)
• Thread : 150 mm
• PACKAGE INCLUDE:
• 56mm resonance
• 3 Steps Reducer
