Regarde les commentaires ......
Nice motors. I blew apart one blade had wires backwards. Make sure guys not to spin it up too fast before you find out your direction or it will snap the blade when the screw comes loose. overall decent.
Not sure if it was defective but the fan impacted the shroud on the first run, didn't get to 1/3rd throttle before it stripped the fan blades and shot them all over the room.. not happy
i was testing it holding in my hand and it just exploded, so not recommending to test it by holding in the hand. other than that product was as described
I connected the EDF to a 12amp ESC & 2 cell (7.4v) lipo. I taped the EDF to a length of wood, making sure that it did not distort the housing. It would have been unsafe to hold the EDF in my hand for testing. When I switched on the fan flew off ! I should have ensured that its screw was tight. On the next test the EDF ran well, giving lots of power. I look forward to fitting it into a plane.
Testing motor on 2S battery it explose in my hand. Bad balanced, fan has a gap with a shaft. Disappointed.
Je conseille vraiment de se limiter à 2S
Vérif de l'assemblage rotor
Ne pas tester en tenant la turbine dans la main
