jpparisy;2299974 à dit:J'ai un doute qui perturbe ma sieste !
Montre nous le code complet que tu as écrit avec le programme d'interruptions.
voiloux:
//this programm will put out a PPM signal
//////////////////////CONFIGURATION///////////////////////////////
#define chanel_number 8 //set the number of chanels
#define default_servo_value 1500 //set the default servo value
#define PPM_FrLen 22000 //set the PPM frame length in microseconds (1ms = 1000µs)
#define PPM_PulseLen 400 //set the pulse length
#define onState 0 //set polarity: 1 is positive, 0 is negative
#define sigPin 9 //set PPM signal pin on the arduino
/*this array holds the servo values for the ppm signal
change theese values in your code (usually servo values are between 1000 and 2000)*/
int ppm[chanel_number];
void setup(){
//initiallize default ppm values
for(int i=0; i<chanel_number; i++){
ppm= default_servo_value;
pinMode(sigPin, OUTPUT);
digitalWrite(sigPin, !onState); //set the PPM signal pin to the default state (off)
void loop(){
//put main code here
ppmWrite();
void ppmWrite(){ //generate PPM signal
static unsigned long lastFrLen;
static unsigned long lastServo;
static unsigned long lastPulse;
static boolean PPM_run;
static boolean pulse;
static boolean pulseStart = true;
static byte counter;
static byte part = true;
if(micros() - lastFrLen >= PPM_FrLen){ //start PPM signal after PPM_FrLen has passed
lastFrLen = micros();
PPM_run = true;
if(counter >= chanel_number){
PPM_run = false;
counter = 0;
pulse = true; //put out the last pulse
if(PPM_run){
if (part){ //put out the pulse
pulse = true;
part = false;
lastServo = micros();
else{ //wait till servo signal time (values from the ppm array) has passed
if(micros() - lastServo >= ppm[counter]){
counter++; //do the next channel
part = true;
if(pulse){
if(pulseStart == true){ //start the pulse
digitalWrite(sigPin, onState);
pulseStart = false;
lastPulse = micros();
else{ //will wait till PPM_PulseLen has passed and finish the pulse
if(micros() - lastPulse >= PPM_PulseLen){
pulse = false;
pulseStart = true;
Dan,
