kallem
Le petit nouveau
Regarde dans le review en dessous:
Spinner diameter needed: 35mm (with -2mm of the nose trimmed off for thrust angle of 1,5° down) Max servo width: ailerons 10mm, flaps 12mm Max motor diameter: the nose has a tapered shape: inside diameter in the front: 33mm , 1,5 cm to the back diameter is just over 35mm and 6cm more to the back the diameter is almost 38mm
